02 700 sportsman
Old Jan 5, 2009 | 11:26 AM
petergoyer's Avatar
Default 02 700 sportsman
i got a sweetheart of a deal on an 02 for like 500 bucks, the previous owner was a "do it yerselfer" and drained th oil and coolant for his 500k service, problem is he forgot to add coolant, long story short i bought the bike and had the motor rebuilt, allong with many new parts as it had been sitting for a while, ie, intake manifold, bearing, boots ect,
the bike ran fine for about 2 months then i took it out the other day and it seemed to not be the powerhouse it used to be, and at about 3/4 throttle it sputters and there is no throttle responce, it almost actl like it is choking,
the guys riding behind me said they some some black smoke, when i run it in my garage im getting some black sut on the floor,
it runs great at low RPM then when yo push it, it starts acting up
im at a loss, it ran fine then abng runs not so fine..............
any ideas ????
thanks
Pete
Old Jan 5, 2009 | 11:31 AM
Hotdogmb's Avatar
02 700's were know for bad coil packs. Could just be a dirty carb or bad filter too.
Old Jan 5, 2009 | 12:27 PM
petergoyer's Avatar
thats a great place to start, i figured it was allong those lines,
thanks!!!
Old Jan 5, 2009 | 12:43 PM
MECHANIKE's Avatar
welcome,make sure you have at least 1/8" play in the thumb throttle.might be trying to turn the spark off.... adjust on cable up cable from throttle...
Old Jan 5, 2009 | 02:14 PM
petergoyer's Avatar
ill give that a try and let you know
thanks guys!!!!
Old Jan 6, 2009 | 09:57 AM
petergoyer's Avatar
gave that a look over last night,
throttle cable had a little play in it, so its ok,
thanks anyway
Old Feb 10, 2009 | 08:21 AM
petergoyer's Avatar
i figured it out,
the bike was let sit in the rain for so long, the needle , or choke jet, whatever its called, was stuck part way open in the carb, a little wd40 and i was back in business, damn thing never ran so good.
thank for the help!!!!!!
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
