Swaybar mod to fit 11's on the rear of an XP
Old Feb 4, 2009 | 09:22 AM
  #41
loaderboy's Avatar
Default XP with 27x11x14 XTRs mounted on stock wheels...
thanks H.O. you are probably right about the metal getting brittle. now my only problem is that my small trailer is only 49.5" inside. Im not sure if 11" wide rears are gonna fit anyway, gonna be a tight fit. wheel spacers are totally out of the question. happy trails!!
Old Feb 4, 2009 | 11:28 AM
  #42
HIGHOCTANE's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: loaderboy
thanks H.O. you are probably right about the metal getting brittle. now my only problem is that my small trailer is only 49.5" inside. Im not sure if 11" wide rears are gonna fit anyway, gonna be a tight fit. wheel spacers are totally out of the question. happy trails!!</end quote></div>
Yeah IIRC mine sits right at 48.5..the 50.5 above was a joke about how tight the trail was..I need to measure it again after that ride it may have settled a little.
It's going to depend on which 11" tire you go with also. Another thing to consider is the track changes a bit with suspension movement..it gets narrower with the suspension extended,wider when the suspension is compressed... the difference isn't huge but is measurable.
Old Feb 4, 2009 | 06:10 PM
  #43
600Grizzly's Avatar
My trailer is 48 1/2 so I can relate to your problem. It seems funny if I have to load the 850 on my 8 ft.x 12 ft. flat deck trailer but it's going to have to do.
Take care
Dave
Old Feb 5, 2009 | 07:44 AM
  #44
HIGHOCTANE's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 600Grizzly
Take care
Dave</end quote></div>
Dave-have you bent the swaybar and removed the spacers and tried it on the trailer?
Old Feb 10, 2009 | 08:56 AM
  #45
*5 J's*'s Avatar
I have the same issue. I would like a new set of sneakers, but my trailer is only 48" wide. Stock just fits - and a new trailer is not in the budget. I would like to get new tires that maintain factory width.
Old Feb 10, 2009 | 11:09 PM
  #46
JBF2's Avatar
What about the Duro Power Grip tires? I see they have 26x8x14 and 26x10x14 which is the same size as stock. Would these be something that would upgrade the stock tires yet keep everything the same as stock? I've been thinking when it is time to upgrade I would like stay as close to stock as I can also. What do you guys think? I know they are not a BH but I have read that those who have then sure seem to like them.
http://www.rockymountainatv.co...Id=17573#vehicleSelect
Old Feb 17, 2009 | 07:22 PM
  #47
RED800's Avatar
when i do the "swaybar mod" will their be any ill effects from riding double alot?
Old Mar 18, 2009 | 06:52 AM
  #48
HIGHOCTANE's Avatar
I re-titled this thread. I've received several PMs people were having trouble finding it. Hopefully the new title will help.
Old Mar 20, 2009 | 05:19 PM
  #49
ductmate's Avatar
if i may i have a question How did you bend the swaybar and what did you mean by rolled it i have been staring at my swaybars for a while and just cannot seem to see how to bend that bar it looks prety beefy did you have to remove them first?
Old Mar 20, 2009 | 05:40 PM
  #50
HIGHOCTANE's Avatar
Default Swaybar mod to fit 11's on the rear of an XP
You are in luck..I had to bend it a little more today to clear the bighorns..so i too a pic.
You just need to disconnect the ends to bend it...it takes some force to bend I did it by hand before..this time used a cheater bar on the strap lever..
Don't worry about the strap popping off..I was concerned about that previously..it happened today..no big deal...well the strap ratchet did land on on of my cameras and ruin it [img]i/expressions/face-icon-small-sad.gif[/img]..but no other harm done..wasn't as violent as I expected..
By rolling I mean bending the flat outboard edge of the stamped steel so the sharp edge isn't facing the tire...I only did that becasue initally I was concerned the bar might spread back out a little..it hasn't so I wouldn't worry about that..as long as you have clearance with the tires off the ground(ie suspension fully extended) you'll be fine..
