Another 3X4 Sportsman 500 HO
Old Mar 11, 2009 | 12:44 PM
Daisy500's Avatar
Default Another 3X4 Sportsman 500 HO
I have had each side apart about 6-8 times. I think that I have a pretty good feel for how tight they should be. Switching everything back and forth, methodicly, trying to narrow down what the problem is. Thanks again.
Old Mar 11, 2009 | 08:59 PM
gatess's Avatar
I may be wrong but I was under the impression that the speedo had to be functional for the AWD to function properly,
Gates
Old Mar 12, 2009 | 08:05 AM
Daisy500's Avatar
In some cases yes, if the coils will not engage. In my case it seams to be a mechanical problem. If my hub had a defect of some kind I would have no problem replacing it, but it appears to look fine and I just having a hard time spending $200 just to see if that is the problem.
Old Mar 12, 2009 | 08:18 AM
gatess's Avatar
have you tried it in reverse with the override depressed
gates
Old Mar 12, 2009 | 08:26 AM
  #15
Daisy500's Avatar
yes.
Old Mar 12, 2009 | 09:51 AM
  #16
gatess's Avatar
I would think that if the hub was the problem it would engage erratically, or try to engage, maybe try it with all four wheels off the ground on jack stands to see if it partially engages or tries to, you got a good one here, hope you find your problem, let me know if you do, I'd be interested in knowing
gates
Old Mar 12, 2009 | 10:19 AM
  #17
Daisy500's Avatar
I have not tried it with all four wheels up in the air yet, but I have tested lots with snow, ice, and up against trees. In the deep snow the wheel will want to try to engage a little bit every once in a while, but is very spontainious. I just seem to be one of those guys that have the unusual problem that know one has heard about. Thanks again, Dale.
Old Mar 12, 2009 | 11:24 AM
  #18
Motohoppie's Avatar
I had this same problem on my 2001. Mine turned out to be the innner and outter magnet poles were not set correct anymore and the clutch was not engaging. The otter pole was out to far so I tapped it back with a rubber mallet and it works fine. I got all the info and repair inforamtion from a manual.
Old Mar 12, 2009 | 11:47 AM
  #19
Daisy500's Avatar
Thank you, I will look in to that. It might be the same problem. That front wheel took a pretty hard hit before I noticed the 4x4 not working. Thanks again, Dale.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
