SPORTSMAN 90
Old Mar 23, 2009 | 12:42 PM
weatherford's Avatar
Default SPORTSMAN 90
My sportsman 90 will idle forever but when i give it gas it revs up and quits.
I have cleaned the carb well.
It seem to be choking out .
It has some sort of electronc type choke.
How can I test if this is the problem.
The part cost $100.
HELP
Old Mar 23, 2009 | 03:45 PM
teamplayer's Avatar
If you unplug the connection to the electric choke, it will be as if the choke is off. Have you checked the air filter and ducting? These are very touchy about that.
Old Mar 23, 2009 | 07:29 PM
It dose the same thing with the chocke disconnected.
I have kept the air cleaner off because because of the hassel when trying to figure out the carb problem.
My son had been riding most of the day then it started to act up.
He did do alot of stream crossing that day.
I twice had to clean the air filter because of water.
thank you for the insite.
Any other thoughts
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
