96 Sportsman 500 Rear CV swap
Dose any know or has done the old Rear half shaft U-Joint stye from 96/98 can be swap over to newer full CV half shaft why I ask it would be a better way to go and eazy to get parts and I can't find and any Rear half shaft U-Joint stye to replace the bad one I have which get bent due to cap that come out.
Here is a copy paste from a another site.
souce.Reliability of u joint axles
i have a 96 500 and i will tell you they are very weak hense the reason they were discontinued, they were only in the 500 for 2 years 96 and some 97s and the 335s i had both, they will not last and i seem to be the only one who has upgraded these it takes some money and work, must replace with cv of your choice, and the outer hub has to be changed the the newer style for the cv to go through, also there is major clearance issue with the cv by the trans and the where the a arms bolt up nothing a hammer and grinder wont fix, i did this last summer after hundreds spent replacing the old ujoints over and over, not to mention try and find replacement parts when something other than the u joint bust, takes forever even on ebay and is extremely high i promise just switch over and save time and money, nothing has broken with 27s and two in lift in very hard riding since
bzdok1234
30
02-23-2016 01:55 PM
