how to break in a new belt
Old Apr 30, 2009 | 05:13 PM
chuck_raduenz's Avatar
i can see when taking it apart to fix something to do a cleaning. iv done it on replacing the cv boots. it dont say you have to. but i do just in case of dirt or something i cant see. other than that i wouldnt just take it apart to just clean it if it works. but i guess if it is dirty id do it.
Old Apr 30, 2009 | 06:50 PM
HIGHOCTANE's Avatar
I don't think anyone was saying to just take it apart and clean it,they were talking about during a belt replacement. BUT there is an hour interval for inspecting the belt..so if you pull the cover to look at the belt and clutches..which you should periodically..that would be a good time to clean up. Preventative maintenance.
Old Apr 30, 2009 | 07:12 PM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Chuck, you know how many bolts hold the belt cover on? Just razzing!!!
Old Apr 30, 2009 | 07:24 PM
FunRide's Avatar
Originally Posted by upnort
Clean the clutch faces to get the old glaze off, a green scrubbie works well in a solvent that will not leave a residue. There are cleaners that do not leave residue. I have a no residue spray solvent but can't rem brand that does well.
Can anybody chime in on this solvent. I gotta think rubbing alcohol would do the trick...Acetone maybe? Acetone is good stuff.
Acetone - Wikipedia, the free encyclopedia
Old Apr 30, 2009 | 07:25 PM
  #15
DCT's Avatar
DCT
Banned
Originally Posted by HIGHOCTANE
The washing of the belt is not in the manual,but if releasing agents are used in the manufacturing process it is probably a good idea,I have done it and maybe it was my imagination but the belt seemed to be grippy right off the bat compared to just throwing a new belt on without washing it. I use Dawn it cuts oils well. Just make sure you rinse well and let it dry completely.
JMO
Yep, talked to a guy at my dealer a while back who is into snowmobiles, and snowmobile racing. He told me to use 303 Aerospace Cleaner (not the protectant) to clean up a new belt prior to installation. Since I already use that cleaner for detailing, and being that it's biodegradable and is safe to use on anything that it is safe to use water on... I will use it.
He also told me to break in a new belt with a few quick short bursts in low range. Then drive it normal for a while... then a few more quick short bursts in low range. Not sure if he is right... but it sounds fine to me.
Old Apr 30, 2009 | 09:06 PM
  #16
there was about 6 on my 00 and thing theres about 8 on this one. if it only was as easy as taking off the 6-8 screws it be easy but can you take your clutch cover off with out removing the foot well and fender?
Old May 1, 2009 | 06:34 PM
  #17
Yep, and now I know you have been inside the belt cover snoopin' around there Chuck!!
Old May 1, 2009 | 07:03 PM
  #18
yup iv been in the cvt. it was a pain to get to. taking off the fender and foot well was a bigger pain on my old one. just becuse of all the screws and bolts. but i did that on my old 00'. i had to take it off since i sunk it at a local river. i havent taken my new on apart yet. as i havent needed to yet. but i know my newer one if a bit easyier since there are more push pins than screws.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
nastyblaster100
Sep 13, 2015 01:19 PM
