Transmision oil?
Old May 1, 2009 | 08:09 PM
Dannycouture's Avatar
Default Transmision oil?
What type of oil do I use in the transmision/rear end my 2006 polaris 500X2 quad ?
Old May 1, 2009 | 08:18 PM
Polaris AGL fluid. Drain plug on the right,fill plug on the left side of the case. Fill to bottom of threads.
Old May 1, 2009 | 08:27 PM
Does it have to be Polaris oil? And what does AGL stand for or mean.
Old May 1, 2009 | 09:06 PM
DCT's Avatar
DCT
Banned
AGL = Angle Drive Gear Lube
I use AMSOIL 2000 Synthetic Chaincase lube. However, the Polaris AGL is less expensive and is probably all you need.
Old May 1, 2009 | 11:58 PM
plumbob's Avatar
AGL stands for Atv Gearcase Lubricant.
Old May 2, 2009 | 09:37 AM
TLC's Avatar
TLC
I use Shell synthetic chain case oil. As long as it a chain case oil it will meat the spec.
driller08
1) Engine problems..
Jul 15, 2013 09:30 AM
norcaleiger
Jan 11, 2012 12:37 AM
hummer3d
Mar 7, 2010 06:39 PM
YIYO
Mar 2, 2010 12:28 AM
