HELP!! Scambler 400 problems!!!!
Old May 17, 2009 | 08:33 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
And the stator spins a bit also, throwing timing out of whack. I "had" 3 of the '99 Scramblers 400's, and if you don't line up the timing marks, those damn 400's wouldn't start. Extra oil in the counter balancer isn't the problem, has an overflow tube on it, and only takes 4-5 ounces of oil in the first place, your issue is definitely in the stator/electrical area
Old May 17, 2009 | 10:55 AM
&Drew's Avatar
Originally Posted by MrMarty51
Sheared flywheel key sure makes a lawn mower run like crap,if at all,with backfiring.
thats what i think it is cuz ive been cranking that electric start all day
nd it went from good to worst den from worst to not working
ima take the flywheel out 2day nd see
Old May 17, 2009 | 10:58 AM
&Drew's Avatar
yup its the only other thing that needs to be checked...
ill take out the flywheel 2day
thanks
Old May 26, 2009 | 08:49 PM
&Drew's Avatar
hey guys thanks for all the help it was the flywheel key it broke i put a new one on already started right up
but a its not running right doesnt idle at all and back fires a bit
have to have it half throttle to start it
and very slow throttle response (bogging)
Old May 31, 2009 | 12:22 PM
  #15
obsidian231's Avatar
sounds like the carb needs to be cleaned and or adjusted. you said you found oil in the crank which isn't good i would think seal might be bad on crank. It will suck counterbalance oil into piston and make it run like that also. What does your exhaust look like does it smoke alot?
Old May 31, 2009 | 10:29 PM
  #16
itch's Avatar
broken skirt on the exhaust side from the backfire also maybe? would that cause this?
just a thought
Old Jun 1, 2009 | 05:58 AM
  #17
carb issues, pilot jet is plugged
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
