No AWD on 97 Sportsman 500
You might check you gear selector switch in the shift box by pressing a little forward in drive or low range on shift lever and see if awd lights up. If internal switch becomes worn can cause no power to awd switch. This completes the circuit. Dont know if this is your problem or not since you said problem came up after you changed the battery? Also might check the bulb in the switch (small bulb inside at back)
chingchangchong
08-07-2022 11:36 AM
slowgsxr97
09-08-2015 07:33 PM
cdstang
08-31-2015 07:52 AM
