Bighorn Tires on a 2009 XP550
Old Jun 2, 2009 | 10:23 PM
Pasqualie47's Avatar
Default Bighorn Tires on a 2009 XP550
I just bought a new set of tires for my XP550, and when I put the rear wheel on, it touches the sway bar. Has anyone else had a problem like this? And of coarse, if you did, how did you fix it?
Dave
Old Jun 2, 2009 | 10:28 PM
RickCJ7's Avatar
Dave
Wheel spacers or modify the sway bar.
Old Jun 2, 2009 | 10:32 PM
Modify the sway bar, you mean bend it a little, or extend up the vertical connectors.
Thanks Dave
Old Jun 2, 2009 | 11:53 PM
flatout XP's Avatar
To modify the sway bar you need to bend it if you do a search on High Lifter there are posts on how to do it Never done it myself but it is not suppose to effect handeling.
Old Jun 3, 2009 | 12:27 AM
NoJoke's Avatar
Pasqualie47.....are you using the stock wheels?
Old Jun 3, 2009 | 01:18 AM
biz4two's Avatar
Arrow
Dave
Here is the sway-bar mode link...
http://forums.atvconnection.com/pola...s-rear-xp.html
Hope this helps...
biz
Old Jun 3, 2009 | 02:43 AM
nkkiegem123's Avatar
I tried bending the sway bar and still it experiences the same problem. Anyway, let me look on google about fixing High Lifter. thanks for this
__________________________________________________ ______
-I do not fear failure. I only fear the "slowing up" of the engine inside of me which is pounding, saying, "Keep going, someone must be on top, why not you?
Old Jun 3, 2009 | 08:23 AM
Dublin's Avatar
Maybe you could have your wife talk to my wife?
Pardon the newbie question but would it be an absolute no-no to just remove the sway bar? I know I threw my jeep's rear sway bar away years ago. I also realize a Jeep and ATV are not the same animals so just curious if the sway bar on an ATV is necessary or just there to keep Polaris out of court?
Cheers,
cc
Old Jun 3, 2009 | 04:39 PM
HIGHOCTANE's Avatar
The post on highlifter is basically the same as the above link that biz posted..I made threads here and on highlifter..if you bent it and it is still touching you did not bend it enough..it doesn't bend easily..you have to tighten the strap pretty dang tight..as it will relax some when you remove the strap..
Dublin..you could remove the sway bar but you would quickly find that the body roll is increased dramatically and likely end up putting it back on.
Old Jun 3, 2009 | 08:55 PM
Thank you so much for the info. I bent it tonight, and it is all fixed. I have plenty of room now.
Dave
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
braap123
Sep 7, 2015 12:58 PM
