cv joint
Old Jun 11, 2009 | 04:39 PM
michael l's Avatar
jacked it up today and checked it out.. it doesn't move around as much as the other side.. took the tire off and moved the boot back so i could see and i think that there is a broke spot in the cv joint.. i'll try to get a picture up in the morning, i'm working in the afternoons this week..
Old Jun 11, 2009 | 04:42 PM
michael l's Avatar
with the tire off and the bike in "N" i can roll the hub backwards and feel the pop, and when it pops the cv joint kind of jams and then starts to move again...
Old Jun 12, 2009 | 07:09 PM
michael l's Avatar
i've been looking around online and can not find anywhere the price of a turner axle.. would you put a turner or gorilla axle?? what i've read is gorilla is the same same axle as stock but bigger cv joints and turner is alot bigger than both.. one more question. could i replace them one at a time or would i need to replace them all at the same time.. thanks for any help...
Old Jun 12, 2009 | 09:53 PM
helmethair78's Avatar
Turner Cycles Home This is the only place I know to get Turner axels.
Old Jun 12, 2009 | 10:14 PM
  #15
war1ock's Avatar
I like Gorilla Axles myself. If ur replacing with OEM u can do one at a time but if ur putting aftermarket id put them on in sets. Fronts and Backs. Either or
Old Jun 13, 2009 | 01:48 PM
  #16
michael l's Avatar
thanks for the info.. i think that i am going to ride it tell it completely goes out.. how much price different would it be to go with aftermarket? i found the turner website but it does not say how much it would be for a sportsman 800.. i've also heard that gorilla axles have a pop to them is this true..
Old Jun 16, 2009 | 01:02 AM
  #17
bigboss6920's Avatar
im not an expert but i have rebuilt quite a few CV joints and shafts for my friends...i have rebuilt both the front ones on my suzuki vinson... i didnt really read all the post so forgive me if im repeating what some one else has said... basically if its poping its junk... its only going to get worse... and they do explode sometimes when then go and its not fun trying to get them home when you have your shaft banging around under the machine... when mine started popping the first time i found out that it was the grove that the ***** inside the joint run in... i had put enough pressure on the joint for the ***** to wreck that grove and then everytime the ball would go by the divets it made in the grove it would pop and catch... until it finally exploded the cage that holds the *****... in both my cases the out joint was the one that went and you can not buy just that end you have to buy the hole shaft for $389... i could get gorillas for $349... but in my case im a machinest and i was able to remake the parts that i screwed up and have them hardened and saved my self some money... gorillas are the way to go if your going to replace them... and if you dont do it soon you will end up wrecking the bearings as well... depending on your experience it shouldnt take you more then an hour to fix... greaseing them will only make the noise go away for a bit but the problem is still there...
if you have a ?'s let me know and i will help any way that i can....
good luck
Old Jun 16, 2009 | 10:58 PM
  #18
war1ock's Avatar
Not all true. You can get a OEM polaris end joint. You dont have to buy the whole thing. Ive rebuilt two of my buddys outer joints that didnt have a thing wrong with them inner. NOt sure pricing but if you jsut want to replace one id go OEM. I wouldnt wait till it completely breaks jsut in case it is a catastrophic as he said. My buddy rode his till it broke but it just didnt give power so he was riding around in one wheel drive.
Old Jun 17, 2009 | 03:14 AM
  #19
chuck_raduenz's Avatar
not shure what yr urs is but a whole shaft isent $389 but 06, 07, and looks to be 08s are
1332654 ASM-DRIVE SHAFT,SPTMN,REAR 306.62
Old Jun 17, 2009 | 03:11 PM
  #20
michael l's Avatar
thanks for the information.. does anybody run the turner axles on here.. how do they hold up?? no one knows a price for them..
so if it went out while i was riding would i be able to get it back home or to the truck?? what i'm asking will i be able to ride it out of the woods?? if not does anybody have a special place that is cheap to get parts from if i stay with stock..
89Lt250r
Sep 7, 2015 07:53 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
Peter_
Jul 18, 2015 07:06 AM
