clutch knocking
Old Jul 18, 2009 | 09:04 AM
island hunter's Avatar
Default clutch knocking
I have a 03 400 sportsman and i noticed the clutch starts knocking when warmed up.I took the cover off and there is a little play from side to side.Is there suppose to be any play at all.I also put a new belt on.What could be the problem?
At first i thought the the noise was coming from the motor.
Old Jul 18, 2009 | 09:52 AM
scramblerXrated's Avatar
there are little buttons(6 total) that the clutch slides out on, in the spider towers. they are a wear part, and need to be replaced. i have an 02 and just replaced mine a few months ago. so your probably due.
X
Old Jul 18, 2009 | 09:57 AM
gumbyman's Avatar
time for a rebuild play tolerance is very small if you feel it from side to side buttons are done.....replace before they cause damage to the slide...and the bushings.... i would replace the bushing reguardless.... even if they look ok...
Old Jul 18, 2009 | 11:31 AM
thanks guys i just ordered a puller and try it myself.It can't be that hard is it.
Old Jul 18, 2009 | 11:56 AM
SCRAMBLER500XXX's Avatar
take the clutch apart and then take it to the dealer to have them remove and install the bushings, they are very soft and damaged easily, you can change the buttons and finish the clutch assembly yourself.
Old Jul 18, 2009 | 07:25 PM
gumbyman's Avatar
if you know someone that has a bearing race driver set they work good...... the bushings are soft but managable... what ever you use to knock them in /out make sure the o-d matches correctly with the i-d if the clutch housing or your in for trouble....
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
