2002 sportsman fluid change
i started doing a service on my 2002 Sportman 700 twin. but i cant find where you fill the transmission fluid at? Where is the front and rear gear case fill at also? i found all the drains buit cant find the fill. I feel stupid for not being able to figure this one out!
You need to pull the right side footwell off and that will get you access to the trans. plug. The fill plug for the front is the round nut that has an allen wrench fitting to take it off. The rear I think is the same(?). You need a long piece of tubing attached to the gear lube to get into the diff. cases.
