Front Prop Shaft Roll Pin Removal
Old Aug 1, 2009 | 09:10 AM
switzomatic's Avatar
Default Shaft
Double check that you got all of the roll pin out. Sometimes they come apart when you tap them out. Can't say I've ever seen one stuck like that. Might need to try a little heat on the prop shaft. If all else fails you may have to remove the u-joint while it's on the machine and then try to tackle the shaft. May be a bit tricky but it can be done.
Reactant
Mar 30, 2022 02:08 AM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
