'08 500 efi, gonna grease it..
Old Aug 4, 2009 | 11:23 PM
TDAWGCOUG's Avatar
Default '08 500 efi, gonna grease it..
Besides buying the grease, any trick to greasing where it says to? Do I just grease over the fitting, or do I remove the fitting first?
TIA, This is the first I've attempted to do this!
TDAWG
Old Aug 4, 2009 | 11:34 PM
carlobee's Avatar
i've never had experiences in greasing too so i might well keep an eye on this post and try to look for help. we have diff. units though.
Old Aug 4, 2009 | 11:38 PM
switzomatic's Avatar
Default Grease
Fit the nozzle from the grease gun over the fitting and give it a few pumps but don't pump in so much that it comes out of the rubber boots.
scrambler400enoge's Avatar
Shapeshifter Rider
What do you ride?
When greasing there are zerk fittings no need to take the fittings off, just grease the zerks and go.
Old Aug 5, 2009 | 05:33 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
wipe off zerk with a paper towel before greasing.
Old Aug 5, 2009 | 10:15 PM
TDAWGCOUG's Avatar
Thanks for all the info. I will try it this weekend!
Old Aug 16, 2009 | 02:07 AM
mrtwostroke's Avatar
The main point of greasing it. Is to push out water, so I say grease till you see grease then stop. a greasable part has seals that are intended to keep water out not grease in. so it does no harm to push out some grease.
Irishman301
Sep 23, 2015 01:47 PM
bigred20653
Sep 19, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
