Tires???
Old Dec 1, 2009 | 05:52 PM
  #31
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
12" on the rear is no problem. Front tie rod issue clearance is the issue ith 9" wide tires. I went with 25s due to that clearnce issue.
Old Dec 2, 2009 | 01:45 PM
  #32
blackwaters's Avatar
Well I'm going with the Maxxis Zilla. Ordering up the 27x9x12 fronts and 27x11x12 rears. Just can't beat the price and the light weight design. 20.3 pounds for the front tires and 23.4 pounds for the rear tires. It was a tough decision between the Swamplites and the Maxxis Zilla. Anyways I'll be sure to leave some feedback once I get them and mount them.
Old Dec 3, 2009 | 10:41 AM
  #33
gaspumpcity's Avatar
Pictures too!!!
Old Dec 4, 2009 | 01:36 PM
  #34
Pictures will be included.
Old Dec 23, 2009 | 12:54 AM
  #35
Default Maxxis Zillas
Hey guys just wondering what the lowest air pressure you can run in these tires without them popping off the bead. Here are the specs: 27x9x12 and 27x11x12 on stock rims on a 07 Sportsman 500. Just want to know so when I test them this weekend I can try some different pressure in the snow.
Old Dec 23, 2009 | 06:36 AM
  #36
700 sportsman's Avatar
In the snow, if you not riding over logs and other obstacles that would put pressure on the sidewalls, if your like me and just ride around smoother trails, and plow and cruise around fields, you could probably get away with 3 pounds, but I usually keep mine close to 5, but it depends on the rims and tires, and all kinds of other variables
Old Dec 23, 2009 | 11:11 AM
  #37
Dande's Avatar
Blackwaters, how was the fit in the front, any tie-rod issues with the stock rims?
Keep us posted on how they work in deep snow & let me know if it's a light or wet snow too please.
Thanks,
Dale
Old Dec 23, 2009 | 12:00 PM
  #38
Supposed to get a snow storm over the next few days, so it should be a good test. I will have pictures of clearance and everything else after the weekend hopefully.
Old Dec 28, 2009 | 09:07 PM
  #39
Default Update Tires Are On...
The test ride went well I didn't really notice any power loss with the 27 inch Maxxis Zillas, but they are a light tire. Wheeled in a foot plus of fresh snow up here in Northern Minnesota. Fun times didn't spin a tire going across the field in low just crawling. Pics to come...
Old Dec 30, 2009 | 01:41 PM
  #40
Default Pics Finally!!!
Here you go:
Last pic shows the clearance between the tie-rod end...trust me it doesn't rub.
