Cellanoid Problem?
Old Oct 1, 2009 | 08:58 PM
shane_12m's Avatar
Default Cellanoid Problem?
I have 05 Sp 500, and I fully charged the battery. When I turn the key on I hear the cellanoid clicking. All of the speedometer lights work. I can pull start it and get it running, and it rusn fine but when I turn the lights on it dies. Would the cellanoid be bad or any other suggestions?
Old Oct 1, 2009 | 09:59 PM
UTU's Avatar
UTU
Default Solonoid Problem
check all conections especially all GROUNDS and you can jump the solonoid with the key on to see if the solonoid is bad. First check your battery voltage if its a lil low will give U problems. Sounds like the battery or and not charging.Especially when you turn lights on and dies....
Old Oct 2, 2009 | 07:22 AM
shane_12m's Avatar
I bought a new battery and after a few weeks of sitting the battery was dead.
Old Oct 2, 2009 | 03:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like you having something draining the battery like a short or something powereed on all the time. if theres not a 12 volt constant flow of power and a charging system that is working correctly then when you hit the lights to require more power then it would robthe power from the engine cauisng it to shut it off as it did. if your battery is 100% charged and the solenoid is wokring correclt then it would start w/ the key. as mentioned above w/ the key on jump the to big wires on the solenoid and it should turn the starter over. if it does then the solenoid is bad. but something else is an issue if the battery is being drained just by sitting. imo
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
