fuel filter 850 xp
Old Oct 6, 2009 | 10:35 PM
gaspumpcity's Avatar
Default fuel filter 850 xp
Im told the fuel filter is not inside the fuel tank on my xp 850 is she correct?
Old Oct 6, 2009 | 10:45 PM
deerwagon's Avatar
A fuel "filter" inside the tank...I hope they didn't put a maintenance component inside the tank. I could see the fuel "pump" inside the tank - but not a filter.
Old Oct 7, 2009 | 07:41 AM
Kerbbirds's Avatar
Its probably like the 800, under the front rack.
Old Oct 7, 2009 | 08:09 AM
rancher55's Avatar
The service manual says that there are two fuel filters located within the fuel pump assembly. If the internal fuel pump filters require service, the fuel pump and fuel tank must be replaced as an assembly!
Why would they do something stupid like that!?
This problem needs to be addressed by Polaris! There should be an in-line filter that is serviceable by the owners!
Old Oct 7, 2009 | 08:21 AM
rancher55's Avatar
I suggest that everyone pre-filters their gas prior to putting it into the tank. I'm going to pick up a funnel that you can put filters in to do this! It will make fueling up a bit more of a chore but worth it IMO!
Old Oct 7, 2009 | 09:27 AM
Yes they do have fuel filters inside the fuel tank on some atv and automotive applications. I did a lookup and found there is a filter on our xp that is external here is a link http://parts.polarisind.com/Assemblies.asp
Old Oct 7, 2009 | 10:16 AM
Crap just found out this filter I looked at is for the vent line. Inside the tank my bet.
Old Oct 7, 2009 | 10:38 AM
rancher55's Avatar
That's the problem with having the fuel pump in the tank, there is real no way to have an in-line filter accessible to service. However there could be a filter for the gas going into the tank that rests under the filler cap in the tanks filler neck. This would pre-filter all fuel going into the tank. Polaris or an aftermarket manufacturer should step up and offer one! JMO!
Jazperman
Aug 7, 2016 08:12 PM
Ronk407NY
Feb 13, 2016 11:05 AM
kester_holmes
Sep 10, 2015 08:27 AM
house1
Aug 9, 2015 10:49 PM
Aitch
Jul 21, 2015 09:40 PM
