1999 Leaking Gas at Carb...
Old Oct 8, 2009 | 01:54 PM
polarisbear500's Avatar
Default 1999 Leaking Gas at Carb...
hey all, my 99 500 is leaking a drop of fuel about every 5 seconds from the very bottom of the carburetor. it is coming out of that little nipple or tip at the bottom. the manual looks like it has a drain line on it, but mine does not have a drain hose.
so, why is this dripping? and do i need a drain hose there? thanks
Old Oct 8, 2009 | 04:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
is that the crab float bowl drain that s leaking? it would have a screw to act as the shut off. maybe seal is bad or loose?
Old Oct 8, 2009 | 06:24 PM
i did see a screw in front of it. did not know if i could screw that in all the way or not? anyone know if that will bother anything? thanks
Old Oct 9, 2009 | 06:11 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it's a sp.500 it should be a screw going into the side of the carb. this is the bowl drain. if you unscrew it a little it will flow gas out. if it's already tight then maybe the seal is bad. turn the gas off to the bike and then remove the screw to check if need be. you may want to put something down to catch the gas that will come out.
Old Oct 9, 2009 | 03:46 PM
ok, thanks. i will go check the screw soon as the rain quits. always raining now!!
Old Oct 9, 2009 | 07:41 PM
chuck_raduenz's Avatar
if its comeing outa the drain hose. ill bet it will need a needle and seat. my 87 kawai did that, and my 2000 sportsman did that. if you shut the gas off it will stop. but if you want to fix it ill bet its the needle and seat... are there alota miles on it? if theres about 5 or so thousand on it id say its due.
make shure its not your idel set screw your gona check.
Old Oct 11, 2009 | 04:16 PM
ok, i checked the screw and it was good and tight. i even loosened it and the gas flowed out, then tightened it back. seemed to stop for a few minutes. but i started it and turned it off and it started to drip about every 20 seconds or so. you think i need a needle and seat? if so, where do i order that at? thanks PB500
Old Oct 11, 2009 | 04:33 PM
if it has high miles on or alota running hrs. id say the polaris dealer. i didnt fix mine when it leaked i just took it to a local small engine shop and he fixed it.
Old Oct 11, 2009 | 04:38 PM
dose it leak when its running?
Old Oct 11, 2009 | 04:52 PM
it seems to always just have the constant drip every few seconds or so. i can pull the carb and rebuild it myself. i just need to find a kit. i checked ebay and it pulls every polaris rebuild kit except one for a 99 sportsman 500. is there another polaris model that has the same carb kit that would work? thanks
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
rockinkgin
Sep 25, 2015 01:52 PM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
