Sportsman 500 HO EFI won't start!!
No codes, only a 12 and 61. Start and stop. Put in a new plug, checked the throttle switch, it was adjusted fine. Then checked all sensors that I could and they seem to be plugged in and can't find any bad wires. I can't find anything wrong. When I try to start I get alot of small backfires. Hit the throttle a little bit, starts. Then runs rough. After about one minute, will run smooth and come up to normal idle. The old plug was really black. AAHHH!!!
#16
To check the ETC (elctronic throttle control) open the black box on the right handle bar where the throttle is. Inside, you'll see a set of points. Put a small piece of paper between them and try to start it. If it runs, thats probably the problem. Don't forget to take the paper out when you're done. Good luck.
#17
whitty
67
Feb 24, 2021 02:52 PM
