how to get cables out of sportsman carb
Old Oct 26, 2009 | 11:44 AM
BigRigIns's Avatar
Default how to get cables out of sportsman carb
ok i need help my 03 spotsman 600 is leaking gas out of the drain tube on the bottom of the carb and there is a strong oder of gas the bike runs fine when your on and riding wide open but starts flooding out at a idel now in my exsperince with atv ,snowmobiles ect ..ect.. its alwasy been the float sticking . now here is where the problem lies how in the world do you get the cables out of the carb i have never done one where the cables go into the carb i tore into this on sat nite and had to put it all back togather becase i couldint get the cables out what a pain in the butt any help or a web site explaining this would be greatly appreciated thank everyone in advace for your help.
Old Oct 26, 2009 | 01:35 PM
Ragelite's Avatar
I know on my 04 600 the cables run to the side of the carb and there is a black cover that has 4 screws in and under that is where you undo the throttle cable, the other cable would be the choke and it should be on the outside of the black cover. For both of them you want to pull back the black rubber boot and grab an open end wrench and just start turning them. Let me know if you need any help
Old Oct 26, 2009 | 01:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you refering to the enrichern(choke) cable that go into the side and has a 12mm(i think)nut that holds into place? if so it just unscrews right out and has a plunger on a spring inside that you just slide out. i thought the throttle cable just sets into the throttle carrier.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
Ty Speece
Jul 2, 2015 04:59 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Quadknewbie
Jun 5, 2015 09:58 PM
