2000 Polaris xpedition 425
Yes you have to shift,but overall a good lasting machine. You wont like it at oil change time though,takes about 5 and 1/2 quarts!! Main problems over the the years is the reverse actuator located on right side top of trans shorts out and you have to manually pull the lever for reverse or replace the actuator when you get tired of doing this. OPT
i have an 'o2 expedition and have had real good luck with it.bought it used in '04, besides the reverse actuator and some brakes. that's about it. this spring it was getting to where it wasn't wanting to rev,i adjusted the valves and i got my top-end rpm's back. pulled out a couple jeeps and a pathfinder with it. i wish they still made them, most likely they would have IRS,wouldn't that be awsome ,manual shift and independant rear.
I have had three of them and still have one. Have no intentions to sell it. Very fun bike to ride.
![Smile](https://atvconnection.com/forums/images/icons/icon7.gif)
I've had a 2000 Xpediion for about 3 years nows. Great to ride. Brakes aren't the best, which is another reason to like thegears, I can gear it down to help slow down. Rear axle breakage can be a problem, especially with over-sized tires. Only been stuck a couple of times and my tires are shot, went through areas where an Artic Cat with new mud tires was getting stuck. Can't go wrong with it.
