500 sportsman
Old Mar 24, 2010 | 01:44 PM
h03softail's Avatar
Default 500 sportsman
I have a 2000 500 sportsman that I just purchased used. it has low hours but when idling it trys to pull off or if on very level ground it will pull off. I've tried to idle it down, also it is very difficult to shift from H to R or to L. Where should I start to look or fix?
Old Mar 24, 2010 | 03:50 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. if i understand your question correctly, your bike will creep ahead while in gear at idle right? if correct, the idle should be around 1200 rpm's and should not move ahead. sounds like the ebs bushing or fiber washers in the primary clutch are bad or the clutches are out of alignemnt. sometimes if an engine mount breaks apart it will throw off an alignment. do a search on the forum for creeping ahead and you'll find dozens of post on it.
Old Mar 24, 2010 | 05:05 PM
Mr. Fancy Pants's Avatar
I have the same year Sportsman. Take your gear selector apart and inspect it. Mine had a broken pin (which centers the stick) and also didn't have any oil in it. I took it all apart, clean everything and filled with 20wt oil. It works SOOO much better now.
Old Mar 26, 2010 | 10:00 AM
h03softail's Avatar
Default replacement shock bushings
where can i buy replacement shock bushings for the rear of my 500 sportsman?
Old Mar 26, 2010 | 10:01 AM
h03softail's Avatar
oh, thanks for the feed back guys
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
