2001 Sportsman 500HO CV
I have CV joint clicking when in reverse....and it clicks more often while turning (occasionally does it turning and moving forward). It seems to be on the right rear, but I can't tell if it's the inner or outer. Any suggestions?
Also, we have a ride planned in 2 weekends. Should I be hurrying to replace it considering that it will be my wife riding it (like a girl, of course)? It won't click while jacked off the ground....only when under power with weight on it. Do I have some time left?
you guys need to check the clamps as well as for cracks/ripps. if water can get in it will eat them right up. you can try to regrease them(i have tried)but for the most part once they start clicking they don't stop. i would think it would do it for awhile(depending on if its resealed and no more gets in)before it totally goes bad, but you would have to be the judge your self. if the joint goes that far it will most likey break apart. but i have had one get destroyed, as ripped out, and limped it for awhile, but you need to becareful or least pull the shaft out so it's not hitting anything as it turns. imo
My boot was replaced by the prior owner after the original developed a slight tear in it....hence not being able to find any problems. By now they both appear to be the same condition. I'm going to keep riding it until it gets worse and I can tell which one is bad. Or until it breaks and destroy other parts....
08-11-2015 11:56 PM
