Scrambler Counter Balance Shaft Help
Hey im new to the forums and this is my first post. I think its a little Newb-ish but here it is. I ride a 2000 Polaris Scrambler 400 2-Stroke and I was wondering how to change the counter balance shaft oil? I didnt see anything on here about it and i was wondering if someone could help me. The quad was given to me from a friend after he snapped the output shaft jumping it. It went through 9 years of H3LL with no rebuild on the engine or anything else. im goin through it and rebuilding it but i couldnt find anythin on the counter balance shaft or how to check/change the oil on it. Thanks for all your help in advanced.
James
James
My 2000 explorer has a dip stick that is in front of the air box on the right side ( if your sitting on the bike). It sits pretty low, close to the engine and you have to look for it. It has a slot for a large common screwdriver to fit into. The drain plug is on the bottom side I belive by the transmission drain. Dont know if its exactly the same as your bike but it should be close.
James
James
exmotocrosser
09-13-2019 06:12 AM
