Newly Rebuilt and can't go
Old May 22, 2010 | 03:02 PM
tonythom's Avatar
Default Newly Rebuilt and can't go
I just rebuilt my 03 trailboss and the cdi burned out as is previously posted. Does anyone know, will the 02 cdi work on the 03. My dealer says he has no idea. Same connectors, Also the rectifier also. I believe if I put in a new cdi the rectifier should be changed also. I just rebuilt this ans am now stuck having to drop another $500 in it just to run it. Any ideas or help would be appreciated. Thanks Tony T
Old May 22, 2010 | 05:44 PM
ctdnwakulla's Avatar
Try looking at the Polaris web site and see if the part numbers are the same. If you have not used their site before you will have to register, but it's free.
Old May 22, 2010 | 08:57 PM
Kerbbirds's Avatar
the trailboss 330 hasn't been changed much since they came out, just some plastic changes so i'm sure it'll work
Old May 22, 2010 | 10:53 PM
tonythom's Avatar
Part numbers are totally different.
Old May 23, 2010 | 02:44 AM
RticKwad's Avatar
Runs Stealth!
Since your dealer does not know, it should be his job to find out - IMO!
And IF you still take a chance on buying it to make it work will he honor a RETURN
if it doesn't? I would put it back on him!
Regards,
R'
Old May 23, 2010 | 06:51 AM
tonythom's Avatar
If I buy new from the dealer I will simply buy the right year. The problem is it is almost another $500 in a $1300 quad that is simply a spare for when someone wants to ride with us. I can buy used for 1/3 of that but it would be for an 02 and not an 03. Cannot find the used one that fits an 03 or an 04. Tony
Old May 23, 2010 | 09:38 AM
TLC's Avatar
TLC
From this site OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
02 stator P# 3086464
03 stator P# 3089275 (replaces 3087252)
04 stator P# 3089275
There are site on the web that rebuild and sell rebuilt stators for much cheaper. Here is one of many
RM Stator - Stator, High Performance CDI Box, Regulator Rectifier, High Output Generator, Yamaha Stator, Honda Stator, Stator Repair, Arctic cat ZR stator, Arctic cat thundercat stator, Ski-doo stator repair,Yamaha Warrior stator,Yamaha Grizzly stato
Old May 23, 2010 | 01:13 PM
tonythom's Avatar
RM Stator has no parts available. Cycle parts is till about 400.00. I am trying to avoid that. I only need CDI and Rectifier. I would almost part the bike out and buy another one before I put 400 more into this. Tony
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Steeldon
Sep 9, 2015 09:38 AM
