05 sportsman 800 efi
Old May 28, 2010 | 08:17 PM
kelwinf's Avatar
Default 05 sportsman 800 efi
running rough idle and cuts off. unable to accelarate. runs ok at idle if i keep spraying starting fluid in the air box. fuel pump runs. fuel pressure? air sensor?? help!
Old May 28, 2010 | 09:48 PM
lucky 1's Avatar
check fuel pressure.
Old May 29, 2010 | 05:10 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
injectors plugged? any codes being displayed? you said the fuel pump is operating correctly? some have had to replace fuel pumps from what you have described. maybe fuel filter is partly plugged as well.
Old Jul 8, 2010 | 05:06 PM
kelwinf's Avatar
has 38-40 psi pressure. will accelerate if spraying starting fluid in air box at same time
Old Jul 8, 2010 | 05:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe the tsp wire harness is bad? heard of some bikes that had to be replaced.
Old Jul 8, 2010 | 09:29 PM
helmethair78's Avatar
check the T-bap harness, clean the T-bap sensor, and remove and clean the throttle body. New plugs never hurt also.
Old Jul 9, 2010 | 06:29 PM
JCDEYO25's Avatar
Any codes? Sorry...missed stendori's post..How's the battery...
John
Old Jul 9, 2010 | 08:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
John
thanks ok john , i worte the wrong part anyways lol.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
