stubborn clutch
I have a 04 sp700. I need to get the clutch off,I have the removal tool-looks like a giant bolt that pushes against the crank. I have never had a prob withremoval before .I have a 400ft/lt impact do I need a bigger one or does someone know of a neat trick? thanks
I agree with both methods but I would normally use the grease method last because it makes a mess that takes a while to clean up. If you have tighten the clutch puller and the clutch hasn't popped off you can tap the end of the puller squarely and that will normally do the trick. You dont have to hit it hard. Just tap it. If it doesn't work repeat several times and then use the grease.
cdstang
Aug 31, 2015 07:52 AM
