03 Polaris Sportsman 600 REAR WHEELS problems!
Old Jun 13, 2010 | 03:26 PM
smoothhandling's Avatar
Default 03 Polaris Sportsman 600 REAR WHEELS problems!
I have a 03 polaris sportsman 600, iam having issues with the rear wheels slatting in looking like this / \ from the back. I changed the a-arms and shocks thinking that would help the problem it did but not for long after one ride they went back to slatting. Does anyone know how to correct this problem?
Old Jun 13, 2010 | 03:35 PM
Speeddrive1's Avatar
what about the wheel bearings, are they good?
Old Jun 13, 2010 | 06:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you change the springs when you did the shocks as they are what really gets worn out.
Old Jun 13, 2010 | 06:54 PM
NoisyPoPo's Avatar
Had a similar issue on my 500. The spring were worn out. I put some epi 140lb springs on the rear and it flattened everything back out, made the ride stiffer, but it was worth it to improve the handling and ground clearance.
Old Jun 14, 2010 | 10:30 AM
EPIChad's Avatar
Double check all the a arm bushings, upper and lower. But probably a case of your springs getting soft and worn out.
Old Jun 14, 2010 | 11:50 AM
i changed the shocks (both sides).. and both upper and lower A-arms on both sides.. got the shocks used off E-bay but they looked fine. i talked to the dealer the said mabey bad bushings.
Old Jun 14, 2010 | 11:51 AM
wheel bearings are good.
Old Jun 14, 2010 | 12:40 PM
NoisyPoPo's Avatar
There is a difference between the springs and the shocks. You can have good shocks with worn out springs on them. If you don't have any play in any of the bushings it is worn out springs.
Old Jun 14, 2010 | 08:52 PM
Big600twin's Avatar
I would think the springs are worn. I did the EPI springs and it definately helped the front. In the back the shocks do need to be replaced but I agree with the other posts about the springs. They are what keeps the machine at the correct ride height...
whitty
67
Feb 24, 2021 02:52 PM
skittero
35
Mar 1, 2019 12:39 AM
neilbedwell
Nov 10, 2018 11:02 AM
May 27, 2015 11:15 AM
guy
Mar 2, 2000 10:11 PM
