Sportsman power failure
Old Jun 19, 2010 | 03:46 PM
tonythom's Avatar
Default Sportsman power failure
I was riding the other day and the sportsman just died, 02 500HO. The key would not turn it over, all the indicator lights are out. I could pull start it, (Not something I am willing to try too many times). It will run but no lights, power of any kind. I had to come home and look in my manual for the 20 breaker. I have not tried that yet since I have not got back to where the popo is stored. Should I expect this to fix my complete problem. Thanks Tony
Old Jun 20, 2010 | 08:56 PM
tonythom's Avatar
Anyone know if resetting this breaker should restore power to pod, lights, and starter?
Also how difficult to replace ebs bushing and crush washer in clutch? Thanks Tony
Old Jun 21, 2010 | 07:40 AM
Chad1903's Avatar
This past weekend I had a very similar issue but on my 850xp. No power to the pod except I could see the clock if I pushed the mode button. Other than that dead to world. Bike was in Park, hand brake applied, kill switch in correct position.
Odd thing about it is I hadn't been in any water or had done anything very extreme that day so I knew it had to be a loose connection. Turned out that the electrical plug going into the handle bar headlight & kill switch assy. was pulled out and not seated. Plugged it back in all the way and problem was fixed. Fortunately it took me about 5 minutes to find the problem
Old Jun 21, 2010 | 07:51 AM
TLC's Avatar
TLC
Sounds like a lose connection some where, I think the breaker self sets after a few moment,you do not do anything. Check all connections and take of the front rack and hood and check those connections also.
Really, I rode my for a month using only the pull rope,with the 500's decompression system,it pulled over much easier with one hand than my 250 Moto4 or 350 Big Bear did with two hands.
Old Jun 21, 2010 | 02:16 PM
Kerbbirds's Avatar
check all your battery connections they tend to get loose after time
Old Jun 22, 2010 | 09:47 PM
CrewCabMax's Avatar
My uncle's 03 was doing the same thing. It actually would die and sometimes come right back on. Sometimes it would just die and you would have to wait before it would restart. He found that one of the relays under the front box was shorting out. I'm not sure which one it was, but it was melted. It ran the igniton itsself. The fan was the only thing that would stay on, all the lights and bike itself would die. Hope this helps.
Old Jul 2, 2010 | 09:41 PM
tonythom's Avatar
Traced the wires today, I have power all the way up to ignition switch. But no power when turned on. I jumped from power wire at ignition plug to solenoid wire on same plug and bike started right up. This leads me to believe the switch itself is bad. I have one off my 03 trailboss that I will try.
Also I pulled off the clutch cover. It looks like the bushing is out of it. I can actually grap clutch and get some movement of it rocking on the shaft. Of course it creeps. Does the clutch have to be pulled apart with special tools to replace this. Thanls Tony
Old Jul 3, 2010 | 07:27 AM
Kerbbirds's Avatar
yes you nrrd special tools to get the primary apart, might also check the buttons in the secondary .
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
tweeder
Jul 5, 2015 01:57 PM
