engine squeal when in gear
Old Jul 26, 2010 | 08:16 AM
EPIChad's Avatar
Sounds like the one way bearing. The Polaris Clutch is a dry clutch which means no lubrication on anything. Lube will only get on the belt and clutch sheaves and cause more problems for you.
As far as chainging the one way bearing you have to breakdown the primary clutch. This requires a few specialty tools to take apart. If you only plan on working on your clutch once it is probably cheaper to bring it to a dealer that knows how to change and has the tools.
Old Jul 26, 2010 | 08:49 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Ditto, Also check your motor mounts for loose or broken. The clutches could be out of alignment which is another possibility for the squealing.
Old Jul 26, 2010 | 07:03 PM
blk71cuda's Avatar
Thanks for the help guys
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
MNatv89
Jul 7, 2015 11:36 AM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
