Fan temp sensor?
Old Mar 30, 2017 | 04:53 PM
NO... Disconnecting the sensor just triggers the hot light only to default!! Get this manual as it shows the exact resistance specs on the sensor and other electrical and mechanical checks. Well worth the 5 bucks.2006 Polaris Sportsman 450 Service Manual PDF Download
Old Mar 30, 2017 | 06:31 PM
Atvassassin777's Avatar
OPT would you say my next move would be to buy new sensor? I tried hot wiring fan with.no luck, or is there a different option with fan?
Old Mar 31, 2017 | 08:46 AM
IF the fan doesn't work after jumping it straight to 12volts dc,then just get a new one.If the sensor is still ok(after resistance test),it sends the temp signal to the ecm to kick the fan on.Sensor and ecm are probably doing their part,but fan motor is the problem. Part#2410383.2410383 | eBay Either one of these or you can pay $170 for and oem fan motor which is ridiculous.
Old Mar 31, 2017 | 04:21 PM
Big600twin's Avatar
Just unplug the sensor and use a wire to jump where the plug goes into. Small u shaped wire to go into the connector spot. With the ignition on the fan should turn on....
  #15
Big600twin's Avatar
The sensor is a common piece to fail...
Old Mar 31, 2017 | 04:32 PM
  #16
Same thing on the 800s but you could unplug the sensors and the fan should come on. On the 500 you'd have to jump the connector like you mentioned,but since he said he hot wired the fan direct to a battery and it wouldn't come on,I "assumed" his fan motor had shorted out like many have done,but I've been wrong before.
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
