2006 Sportmen 500 HO Starting problem when cold battery is good
Old Dec 28, 2010 | 02:14 PM
khentige's Avatar
When i replace the recoil case after inspection, and cleaning, do i use use rtv around the full flange when replacing or is there something else i should be using as sealer?
i noticed there is something that looks like a bead of rtv around the full flange now, but just wasn't sure if thats what it is before i bust into it.. it looks clear/white.
Old Dec 28, 2010 | 02:30 PM
TLC's Avatar
TLC
I just rtv, just do not for get to seal the rope handle down over the rope hole as well or you will be in there cleaning it out again before you know it.
Old Dec 28, 2010 | 02:38 PM
khentige's Avatar
last question,
once i remove the recoil case, its been already determined in this thread that nothing will surprise me like springs or anything, but will the bendix come out or fall out on its own? I dont think so but have to ask. Am i taking it out to clean or just spraying wd40 on it and cleaning up, resealing and walla done. is there any allignment required when putting the case back on, or self explanatory?
thanks,
EK in CT
Old Dec 28, 2010 | 02:46 PM
TLC's Avatar
TLC
It will almost fall out, you just put both ends of the drive in there hole, ones in the cover and the other in the crank casts. Also clean pluse coil's face,Its the the little square box next to fly wheel,its face is magnetic and picks up al sorts of small metal filings.
Old Dec 28, 2010 | 04:09 PM
  #15
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
When you clean everything up and relube do not use WD-40! I love the stuff for loosening a sticky joint or bolt but it has the property's to draw moisture over time. Use a quality silicon lube instead on moving parts. A good quality rtv will be fine for resealing the recoil. I always use a high temp on applications that seal against an engine.
Old Dec 28, 2010 | 04:31 PM
  #16
PolarisRich's Avatar
The same thing happened to my bike last week and it turned out to be a bad bendix. I cleaned it all up but the spring that holds the weights had broken. Installed a new bendix and all my problems were solved.
Its not a hard job. The worst part about the whole thing is pulling the bendix out. If you twist the bendix back in and wiggle it alot it will come out without a problem.
Old Jan 5, 2011 | 10:25 AM
  #17
khentige's Avatar
thanks everyone!
just a quick followup to my situation.
I did purchase a new bendix on line from DB Electrical ($30 with shipping) and it arrived in a few days. The job was very easy, and the old bendix was obviously the problem. old one came out easy and the new one went in without a hitch. Cleaned everything up and resealed with RTV. turned the key and she started up just fine.
Again thanks for all the info in this thread.
EK in CT
BigRedGrizzly
Jun 7, 2015 11:06 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
1000gade
May 27, 2015 12:37 PM
MDelby
Oct 1, 1999 08:32 PM
