draining fluids
Old Jul 2, 2011 | 07:39 PM
polarispotter's Avatar
awesome. thank you much appreciated
Old Jul 4, 2011 | 11:04 AM
my quad is train driven. will those hubs still be there that i have to drain?
Old Jul 4, 2011 | 11:05 AM
i meant chain not train
Old Jul 4, 2011 | 12:28 PM
IF you have AWD ,YES there will be hubs to drain. OPT
Old Jul 4, 2011 | 12:35 PM
  #15
Overdrive's Avatar
I am guessing his quad is a 2wd.
Old Jul 5, 2011 | 11:17 AM
  #16
actually there is a button on the quad that wen pressed says AWD. not sure though what it is wen the button isn pressed.
Old Jul 5, 2011 | 04:07 PM
  #17
Then you have the hub activated awd. Drain and fill plug located on hub,center of front wheel.drain,fill at 12 o'clock position,turn until drain /fill hole at 4 o'clock position,drain excess,reinstall plug. Use Polaris Demand Drive Plus hub fluid. OPT
Old Jul 5, 2011 | 09:03 PM
  #18
ok so let me get this straight because i think im misunderstanding you. im supposed to put the hole in the twelve oclock position fill it then drain it after i fill it? doesn that defeat the purpose of filling it? or does it not stay in the hub once filled?
Old Jul 5, 2011 | 09:12 PM
  #19
3/16" allen wrench to remove the plug,turn to 6 o'clock to drain old fluid, turn to 12 o'clock to fill (about a couple ounces or less) THEN turn to 4 o'clock to drain excess, after it quits dripping,then re install plug!!! This allows required level to remain in hub(a little extra won't hurt) OPT
ReconBayou
Oct 31, 2022 05:37 PM
Alex G.
Sep 11, 2017 11:38 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
