800 sportsman using oil
Old Aug 8, 2011 | 03:53 PM
crabtree's Avatar
Default 800 sportsman using oil
my 09 800 sportsman with 5400 miles is using 1 quart of oil every 100 miles any one else have this problem or have any ideal what it could be.Its running fine and does not feel like it lost any power
Old Aug 8, 2011 | 05:04 PM
Overdrive's Avatar
It has got to be your rings. How's your air filter? What oil are you running?
Old Aug 8, 2011 | 05:47 PM
crabtree's Avatar
wouldt it have lost power or hard to start if rings.Im using mobile 1 oil
Old Aug 8, 2011 | 07:45 PM
Spdecat's Avatar
Maybe do a compression test and see what that say's .
Old Aug 8, 2011 | 07:49 PM
Overdrive's Avatar
Your oil rings can be going bad and it will still have good compression and run like new.
The oil has to be bypassing the rings or the valve seals. Or it has to be leaking.
Old Aug 9, 2011 | 08:42 PM
crabtree's Avatar
small amount of oil in air cleaner. im using mobile 1 0w40 i let it idle for ten minutes then reved it up and black smoke came out couldnt tell if it was oil or carbon didnt smell like oil do not see any leaks
Old Aug 10, 2011 | 04:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
how does the plugs look?
Old Aug 10, 2011 | 05:27 PM
Overdrive's Avatar
OK if it is running rich gas gets into your oil and it causes the oil to be very thin. It will use oil if it gets mixed with unburnt gas.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
