1999 Polaris sportsman 335
Old Aug 30, 2011 | 08:39 PM
jekuyken's Avatar
Exclamation 1999 Polaris sportsman 335
Ok I was all excited I just got my first four wheeler. It was running a little rich and it was popping just a little and I could tell it was getting too much gas. I did a little research on different forums and I found that I needed to adjust the idle screw. I started the four wheeler and as it was running I adjusted in small increments. I got it idling better and no more popping. I wanted to let it run for a little while. I was watering the dog and when I got back to the four wheeler it had died. I tried to start it with no luck. It used to start first try. I tried and tried. No luck. Tried adjusting the idle adjustment screw back to original location. Still couldnt get it to start. Is there a starting location and a set amount of turns to get you in the ballpark? I have been tinkering with it and I cant get it started. Any help is greatly appreciated.
Old Aug 30, 2011 | 11:41 PM
Welcome to the forum! Replace the spark plug, sounds like you have a fouled plug,then start at TWO turns out from lightly seated position on carb adjustment. If after adjustment still runs rich,may have to replace the needle and seat. Fuel air screw mainly affects the idle. OPT
Old Aug 31, 2011 | 05:57 AM
TLC's Avatar
TLC
Also this may be out of wack. Polaris ATV Thumb Throttle Maintenance Tips | eHow.com
Old Aug 31, 2011 | 02:48 PM
jekuyken's Avatar
Smile
Thanks. I feel like a idiot. I fouled out my spark plug and didnt even think of it. I got new plug and installed. Put idle screw to two turns. I had to tweak it just a little to about 2.5 turns. Its running now. Thank you guys. I really appreciate the help.
Old Aug 31, 2011 | 07:32 PM
Kerbbirds's Avatar
Thats not the idle screw, its the air screw, Idle screw is on left side under carb, big 1/2 inch **** on it
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
