Sportsman 600 will not idle...OPT your opinion would be appreciated...
First off 2 years is the key word! Hardly any machine unless triple dosed with marine stabil wouldn't crank,Plus I don't think most would if they were! Too much time for a breakdown of octane in the crappy ethanol fuel! Just drain the fuel (siphon hose,or hose with air nozzle in the tank if you're in a hurry!) Clean the nasty carb and jets(gotta be)plus probably going to need a new needle and seat(you're already there! replace it) Only runs with the choke out is a dead give away also!(stopped up jets) OPT
I just had the same issue on my '04 600 after sitting for 3 years. I cleaned the carb and still had the smae problem. The Carb adapter (in between carb and head) is made of a hard rubber and is prone to dry rot. I found a small crack in it and tried a temp fix with epoxy. It ran perfect after that. Once the new parts was installed ($65) it ran even better.
Stirling
08-09-2015 01:49 PM
