my new ATV
Old Jan 14, 2012 | 04:06 PM
  #231
Specta's Avatar
It is a beautiful day here today.
Old Jan 14, 2012 | 06:56 PM
  #232
Specta's Avatar
Is out in front the best place for the brake line??
Old Jan 15, 2012 | 07:18 AM
  #233
bgirard420's Avatar
We have a lot of trails here that are a mix of rough sections where low and slow is the best approach. Then you hit a section that's smooth enough to do 25-30 or so. It gets old fast to switch back and forth all the time.
I can't agree with you more here Moose. It seems like I have to shift more than anyone in our group. It did get much better with the upgraded clutch though I still can't really go more than 25 in low. Beergut and RoadieStar never go below 30 so they don't have to shift
Originally Posted by Specta
I'll see how fast mine will go in low. I can barely get 50 out of it in high on level ground.
Sounds like something is wrong here I get 55 on my 500 with a clutch kit that "decreases top end" and heavy 8 ply tires like those reapers. You should be able to get 60 without a problem IMO. Maybe it needs a few more miles of breaking-in?
Some richochets would hide those lines a little better. Haven't read about too many problems with this setup though.
I like the CanAms idea of centralizing the brakes and getting them off the hub. It keeps all the "guts" tucked inside like a human body and for the most part it works well. Much easier to live without an appendange than without a heart
Old Jan 15, 2012 | 08:24 AM
  #234
Specta's Avatar
I got about 32 mph in low yesterday and it sounded like it was going to blow up
Maybe Polaris knew I was getting it and put a "governor" on it. Doug wont give me his 850 Touring because he says he doesn't want me to kill myself.
I don't mind shifting but even after 650 miles I still haven't got use to the shifter.
The pattern is not right to me, should be PRNHL and I wish the positions were more pronounced. I know why Polaris put low before high.
Three times facing down on steep hills I've knocked it out of park with my leg, once it was no fun at all.
And if you're going down a steep hill and have to turn sharp the handle bars hit my legs partially due to the seat on the Touring has a tendency to push you forward. I think the ergonomics could use a little more attention.
And these Grim Reapers are very aggressive tires in the snow.
Old Jan 15, 2012 | 08:33 AM
  #235
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
The pattern is not right to me, should be PRNHL and I wish the positions were more pronounced. I know why Polaris put low before hig..
that's how it is on the can-am. I always have to tell people who don't usually ride atv's to make sure they are in H not L.
Couple of times some people rode my atv and come back and say "feels slow but lots of power" then I look what gear they are in and they have the selector all the way up in L
I used to do this all the time on my polaris!
I would always hit that damn shifter with my leg.
That's the one thing I like about the suzuki KQ- they put their shifter on the left side up high- so my throttle hand can stay put. I hate shifting with my right hand- but it's not a "deal breaker" for me.
Old Jan 15, 2012 | 09:10 AM
  #236
Chadly1980's Avatar
Maybe Polaris knew I was getting it and put a "governor" on it. Doug wont give me his 850 Touring because he says he doesn't want me to kill myself. .
30 is about the limit for low and yes, it sounds like it is going to blow up on my machine as well. I used to do a lot of low trail riding when I first got it but now if I know I am going to be going 15 MPH or faster at some point I just leave it in High. Although I have never ridden in terrain like yours!
Old Jan 15, 2012 | 09:12 AM
  #237
Specta's Avatar
Wouldn't be a deal breaker for me either but I do prefer the shifter on the left side and a brake lever on the right side.
Old Jan 15, 2012 | 09:15 AM
  #238
Specta's Avatar
I ride more in high than I thought I was going to. I think it's the difference between the 500 and the 550s clutches.
I do spend a lot of time in low.
Old Jan 15, 2012 | 10:20 AM
  #239
Tonyxp's Avatar
I like having low before high. Usually if you put it in high you are going to stay in high for a while. If you are using low you seem to be using reverse more. Like when mudding constantly shifting between the two. Or if you plow snow with it. I think it makes sense to me, however I have only owned polarises but when I try a friends machine out it seems weird.
Old Jan 15, 2012 | 10:26 AM
  #240
Specta's Avatar
It's always the other guys who's is weird.
