green spring or white
Old Mar 15, 2001 | 06:46 PM
jaypet71's Avatar
thinking of changeing the spring on my trailboss which one should i go with we ride alot of tight trail and hills and mud and some wide open trails . also whats involved with changeing the spring how long should it take thanks
Old Mar 15, 2001 | 07:34 PM
500DUSE's Avatar
I changed to the white,I'm in alot of tight twisting trail's that i can just make it trough(i pull a lot of bark out of the rims) I heard the green is REAL jumppy.
Im gonna get a green just for the mud days,they are easy enough to change(20min's)If you do a search on white spring you'll get all the answers you need.
I just did it 2 weeks ago and it's REAL easy
Old Mar 15, 2001 | 11:30 PM
Lurch77's Avatar
I added a green spring to my Blazer. I can't tell you exactly how much difference it made, because I also added a pipe with it.
But I do notice it egages at a much higher RPM then stock. It makes the machine a little more fun in the woods if you ask me. It jumps out of the corners with much better authority.
Old Mar 15, 2001 | 11:41 PM
trailblazerbabe's Avatar
put white spring on 2001 trailblazer ... it helped a lot but did not hurt take off. It still ingages at a reasonable rpm so if you are in a touchy situation it will not hurt and cause a loop out. The green hits pretty hard and if you are at that loop stage you don't want to have it engage to high.
go white it helped a lot and is still usfull.
realoldguy
Old Mar 16, 2001 | 10:02 AM
silverado's Avatar
I put a white spring in my HO and i love it.man this thing flies now.
Old Mar 16, 2001 | 06:21 PM
nauvooguy's Avatar
Hey Lurch, Did the green spring add to the top end any?
Old Mar 16, 2001 | 11:37 PM
Lurch77's Avatar
Sorry, I couldn't tell you. I only took the quad for a test run on a short gravel road. I couldn't open it up long enough to see.
I would guess that it would not add to much though.
Old Mar 18, 2001 | 09:37 AM
silverado's Avatar
I think it actually helped my ho on top end.my speedo will fly past 60 now where before it would take alittle longer.
Pehter
Oct 3, 2024 11:00 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
