Trail Boss 325 stator or regulator problems??
Old Nov 22, 2011 | 02:49 PM
tazland001's Avatar
Default Trail Boss 325 stator or regulator problems??
I have a trail boss 325 that will not charge the battery.
I am not sure if I am testing it right. Using my multimeter set on dcv at 20
readings are
battery not running 12.0
idle 13.84
idled up 17.26
any help would be great.
Thanks
Taz
Old Nov 22, 2011 | 02:53 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Can't say for sure, but those numbers seem like it should be taking a charge. Is this a new battery?
Old Nov 22, 2011 | 03:07 PM
17.26 volts way too much! Should be 14-14.5 volts max! Voltage regulators can under charge OR over charge if bad! If over charging they will usually dry out a battery pretty quick and burn up cells to where they won't hold a charge! Usually they will boil out acid over the clutch cover also. DCV 20 is correct setting! OPT
Old Nov 22, 2011 | 03:10 PM
Supersock
Hired Gun!
Thanks OPT. I think I'm getting better at guessing wrong.
Old Nov 22, 2011 | 03:43 PM
tazland001's Avatar
Thanks for the quick response. You guys rock. I knew I found the right forum to join.
The battery has a bad cell. It wont hold a charge anymore.
Thanks Old. I thought 17.26 was bit high when I reved up the engine.
So when I rev the engines rpms up it should not go over 14.5?
Thanks
Taz
Old Nov 22, 2011 | 03:45 PM
YEP! 14.5 volts max! OPT
Old Nov 23, 2011 | 04:36 PM
Overdrive's Avatar
Sometimes when you have a battery with a bad cell your charging voltage can and will go WAY up like that.
You may find that it will return to normal if you put a good battery on it.
skittero
35
Mar 1, 2019 12:39 AM
wildbill59
Jun 20, 2015 02:26 PM
FWhitt
Jun 13, 2015 02:22 PM
PolarisPower500
May 17, 2015 02:28 PM
Matt24
Aug 3, 1999 07:46 PM
