sportsman 800 hard shifting
will do, i have the service manual so i will check in there. Thanks for the info!
Also what is your thought on the EPI clutch Kits when running larger tires? Am i just waisting money buying doing one and changing the belt?
Like I tell most posters,I spent much of my time just repairing atvs that customers tore up!
Wasn't into mods that much,but I installed clutch kits from Hi-lifter, and Epi. Seems like I installed more Epi kits, but as far as telling you which are better,let the guys that ride em tell you their opinions! From a mechanics viewpoint,the less mods,the better!
I was into reliability more than mods! Others will chime in I'm sure and give their recommendations! Good luck OPT
I hear you and have actually thought about getting some new sneakers in stock size for her. I myself would rather have some reliability and believe the factory did a good job on engineering this bike.
Thanks for the info.
#18
I never had the chance to pull the clutch cover, but i did have to move the quad and noticed it is back to shifting as normal...ok, a little hard but it was like that before.
So i now suspect maybe i had a lot of water and/or debri in there after the last ride, when i get a chance i will pop it off and take a peek.
#19
you better hope you don't have alot of anything in there like water/mud and if it stays in there it's going to cause major issues for the clutches like corrsion,rust freezing up the bearings and rollers. imo
GregM
Mar 6, 2018 06:53 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
