What's the best ATV trailer?
Old Jan 11, 2012 | 09:36 AM
  #21
Originally Posted by Raven95150
Yes, I did add tie down points. I actually pretty much rebuilt the whole trailer. It was originally a camper and the previous owner made it into a flatbed, I bought it from him for $100 and it actually worked just fine the way it was for a while, but then I decided to do some upgrades. I beefed up the frame, replaced the 2000# axle with a 3500# torsion axle, replaced old plywood decking with 2x10 planks, new tires, paint, all new LED lights and wiring, and tongue jack.
A touch heavier now?
Old Jan 12, 2012 | 08:32 AM
  #22
Raven95150's Avatar
Yeah, made it probably a couple hundred pounds heavier but I know it's a solid trailer and I have far less money into it than if I had gone and bought a new trailer.
Old Jan 12, 2012 | 09:37 AM
  #23
My snowmobile trailer currently has 1/2" PT plywood. I'm thinking at some point of putting 5/8" or even 3/4". I also think the extra weight is worth it for the gains in strength.
Old Jan 12, 2012 | 09:58 AM
  #24
Specta's Avatar
get marine grade plywood
Old Jan 12, 2012 | 12:12 PM
  #25
Raven95150's Avatar
My plan was to use 3/4" treated plywood, but I would have needed to use 3 sheets and cut one in half to cover 8x10 feet. It would have been over $100 for 3 sheets. It was about $80 for 10 2x10x10 treated planks, and they are stronger and will last longer.
Old Feb 21, 2012 | 08:47 PM
  #26
3_Polaris_ATVs's Avatar
Sold my 2 place tilt trailer and bought a 4 place for same money. I had some rust through and needed new decking. Just got done with it. I think it will hold 5 or six. Just put two sleds on it to test for size. I paid 400 for it.New wood steel and hardware was 2 hundred. Will put new tires on it before I do any long trips.
Frame was repaired and painted with Rustolem. Wood was painted 2 coats on the bottom and 3 on top. D rings were mounted through the wood in to the steel dead in the center. Yes it is steel but I have an F350 so I dont care. Just made this week end.
Old Feb 22, 2012 | 07:36 PM
  #27
Raven95150's Avatar
Looks nice, pretty much the same thing I did. Take a cheap beat up old trailer and make it like new again. I don't mind that my trailer is heavy either because I also drive and F-350.
Johnny Mac
60
Dec 14, 2019 06:13 PM
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
bigred20653
Oct 2, 2015 10:05 AM
caveeagle
Sep 19, 2015 01:20 PM
