2006 Polaris Sportsman 500 runs bad/quits when fan come on
ok. So i have put a slit in the new hose, purashed a new fan becasue the bearing was going bad, and bought a new battery and i still have issues when the bike gets warm. Is there any way to tell if the controller module is bad without a code?
The atv starts and runs/idles great until it gets warmed up then it takes to spitting and sputtering. It seems to do it between 1800-2200 rpms. Roughly 10-20 mph....
We left off in 2/20/2012 after establishing that you had an efi and were purchasing a new battery. The spitting and sputtering could be the harness wiring on map sensor has a bare wire or internal wire break or the connector itself. This was the most common problem we had on these(map sensor's located on the throttle body) Look at the "sticky" post in the expert section on 700 efi wiring problem which applied to the 500 efi also. This could be your problem. Oem kits (which could fail again) plus after market thicker wire harness kits are available. Cheaper to try this than purchasing the $200 module if you're doing the work yourself. One of the ways to check that the controller module is ok is if it is charging 14 volts back to the battery while running at idle. If you have at least 14 volts going back into the battery,try the map sensor harness repair kit first and see if this solves the problem.. #2876315 is the OEM harness kit number,plus you can check other places such as Ebay for possible better quality ones. IF you aren't charging 14 volts back to the battery,then the controller module could be the problem,plus it's possible to have a bad controller module and harness kit problem at the same time. I had a couple of these at the shop. OPT
#15
Recall was on 2004 to 2006 models on just about all full size carb model Polaris atvs that had the ecm module that controlled charging and fan operation. http://www.atv.info/article.cfm?id=632
#17
Thanks OPT!! I got digging today and found a wire that had a tiny spec of copper showing. I taped it up and so far so good. I ran it for about 30 minutes around the house with no issues. Hopefully this was the problem!
The wire was located in the connector on the side of the engine by your left leg just above the oil filter. Crossing my fingers....
#18
#19
I have a 2006 Polaris sportsman 500 efi and I have been having some issues first the stator went bad and my bike quit firing so I bought a new stator and I had no problems for a couple hours then my battery light started flashing and the battery started slowly dying and the atv slowly lost power till it died I thought it was the battery but I put a new one on it and the problem continues I was wondering if the stator I put I. Could be bad since it didn't do it till I change stators thanks
#20
Welcomed to the forum! Could be a PDM module located at front of atv, controls,charging, fan operation,etc. Check charging back to battery while running should be around 14 volts. If not pull the harness connector going into the pdm and ohm between the three yellow stator wires. Should show the same (or close to the same) resistance(I think around .043 ohms) between yellows. Plus no stator wire should short(zero out ) to ground.If any wire shorts to ground the stator could be the problem. If stator checks out I would suspect the pdm module as the problem. I had several of these short out and not charge. OPT
whitty
67
Feb 24, 2021 02:52 PM
skittero
35
Mar 1, 2019 12:39 AM
Schneider
Jun 4, 2015 11:37 AM
May 27, 2015 11:15 AM
OPT
