Changing tires, best way to pop a bead???
Old Jun 13, 2012 | 11:20 PM
switzomatic's Avatar
I use the hf one and like it a lot. Spray the bead with plenty of soapy water and I leave 2psi in the tires. Very seldom will I come across one that's near impossible to break but when that happens I go with the 2x6/truck method. Great deal from that place on $8 a tire! Well worth it.
Old Jun 14, 2012 | 08:55 AM
Riddler77's Avatar
Got them mounted and they look awesome. Went up a size from 22" to 23" and an inch wider in fronts from 7" to 8". The difference in the ground clearance is crazy! Can't wait to ride soon!
Other mods I have done:
3" wheel spacers
3000# Superwinch
Front brush guard
Hand guards
Cant figure out how to post pics in thread. will ad them to my garage.
Old Jun 18, 2012 | 06:53 PM
Maniac01's Avatar
Just a suggestion on how to seat you beads. Spray lighter fluid around the inside of the rim. It doesnt take much. Hold a fire stick to it and boom.... It is sealed. Flip over the tire if the starter fluid is burning to put it out.
Old Jun 18, 2012 | 07:12 PM
TLC's Avatar
TLC
Our Tire shop is $12 per tire, and thats rip off Canadian pricing.
Old Jun 18, 2012 | 08:53 PM
  #15
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Originally Posted by Jaster94
i got one of them HF tire changers. one of the best $50 i've ever spent. like he said, a little over an hour and you're done with all four!!!!!!! and you don't have to be mad if a dealer bends your rims. i don't worry about bending my own cause it don't happen. i go nice and easy. i also use liquid dishwashing soap to "lube" the beads so the bead tool/tire iron slips right through without much friction. plus, when i air up the tire, the soap helps out on a pressure check/leak test!!!!
I actually welded mine to my trailer they work great!
when I'm home, I actually use my log splitter to pop the tire bead- but the HF tire changer works great once you get the hang of it. can be a little tricky with fancy rims but. It paid for itself 10 times over!
(nomorepropanesmiley)
Old Jun 18, 2012 | 08:59 PM
  #16
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
$25 - $30 / tire around me!
Old Jun 19, 2012 | 07:04 PM
  #17
Jaster94's Avatar
beergut, you didn't patent that mounting did you?. i may copy your idea, OF COURSE, with your permission....
that looks great and sturdy. yeah, i've learned the hard way that it can be tricky, but as you stated, it has paid for itself quite quickly. .
Old Jun 19, 2012 | 07:46 PM
  #18
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
lol
I was tired of tripping over the damn thing so I figured it would be perfect on the trailer.
I painted it all up and I'm really happy with where it is now.
Old Jun 20, 2012 | 09:06 AM
  #19
TLC's Avatar
TLC
3" wheel spacers
3000# Superwinch
Front brush guard
Hand guards
You have 23" tires on a Sportsman?
Ooops,sorry, I just checked your profile,I did not know they made a 300 Sportsman. I have 350 Grizzly 4x4 with 25" stock tires that it handles no problem I bet a 300 Sportsman could go to 24" or 25" without a problem as well if you chose.
Old Jul 3, 2012 | 06:06 AM
  #20
Riddler77's Avatar
Yeah the 08-09 Sportsman 300/400 is the old Hawkeye. Then they went full-size and got rid of the 300 in 2010. It came with stock 22" tires, always wanted bigger. So just came back from a 4 day trip to Maine and put 265 miles on it with the new tires, and man you can feel the difference. Lost a lot of low end power. May put a clutch kit in it. One of the front tires blew a sidewall the first day, but after sending a few pics to RockyMountainATV, they are replacing it! Bonus!!!
Bratman2
Aug 6, 2022 01:42 AM
Ean
Aug 28, 2015 09:39 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
