Xplorer 250 Help
Old Sep 20, 2012 | 01:52 AM
pierson2010's Avatar
Default Xplorer 250 Help
My wheeler is driving me nuts. I am trying to find out which jets I need to be able to a 32:1 fuel to oil ratio better. The jets seem to be plugging after every tank. I don't know anything about jet sizes. Any help is appreciated.
Old Sep 20, 2012 | 07:58 AM
Welcome! 32-1 ratio is way too much oil!! Even our high performance,high compression,modified KTMs ran 36-1 ratio with a good synthetic oil. 40-1 premix is the most you need with good quality gas on the low compression 250. A lot of people I knew used a good synthetic and premixed 50-1(mainly because they were afraid of the auto injection oil pumps) which are generally reliable. Stock jetting on the 2000 Explorer 250 was a 130 main jet and 40 pilot (seal level to about 3000 ft) Plus make sure you mix the gas/oil mixture well in your fuel cans,don't just throw oil in the gas tank. OPT
Old Sep 21, 2012 | 12:24 AM
I run my bike at about 6500 to 9000 feet. So what would the best jetting be?
Old Sep 21, 2012 | 05:04 AM
Don't have the chart in front of me like I had on the wall at the shop showing jetting,but I'd say at least drop down from the 130 main jet to a 115-120 jet at that altitude,BUT best to contact a trusted shop in the area you ride to be more accurate on jetting requirements.Doesn't change the mixture ratio though,32-1 is too much oil! OPT
Old Sep 21, 2012 | 08:36 AM
Thanks for the info. I will get ahold of my local shop and get some new jets. I will change that oil mix tonight if I have time and see if it makes a difference.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
