2000 trailblazer no forward or reverse
Old Jan 26, 2013 | 10:30 AM
Tattered_n_torn's Avatar
Default 2000 trailblazer no forward or reverse
Picked up a 2000 trailblazer for cheap motor runs great. With the side cover off you can see the clutches moving properly and when you give gas it puts the tension on the belt however In Forward or reverse it does nothing, if you put the chain back on it won't roll even in nuteral are these known for trans issues maybe a bent shift fork never owned a automatic so looking for ideas.
Old Jan 26, 2013 | 10:46 AM
If it wont shift into gear with the engine off,then possibly you could have internal gear case problems. Check the obvious first. Check the front sprocket on the gear case(broken /rounded off teeth,splines on the sprocket ground down, just turning on the shaft. Make sure the linkage arm (belcrank) on the gear case is tight and not stripped. You can see if the shift lever while in neutral is centered on the shift slot and not caused by a linkage problem. You can also remove the linkage at the transmission and try a pair of vice grips to see if you can shift the gears. Could be it is in a bind and you can free the shift forks. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
neo27ny
May 14, 2018 12:19 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
