cylinder honing
Old Mar 2, 2013 | 11:21 AM
  #21
neo27ny's Avatar
Well I got the clutch off, turn the crank and still feel the grinding...onto the next thing. I'll pull the recoil if the magnets are good then I'm gonna start a complete teardown and rebuild.
Old Mar 2, 2013 | 09:08 PM
  #22
neo27ny's Avatar
the magnets weren't shattered...Is there a tolerance for main bearing play or should there be no play at all? The left hand side has a hair of play when I move the crank, right hand side seems to vary depending what position I turn the flywheel/crank but it does seem to move a good amount. Anyway I"ll update when I find out more.
Old Mar 2, 2013 | 09:18 PM
  #23
There should be NO movement up and down,side to side on the crank shaft! Sounds like it's time for a tear down.
Old Mar 3, 2013 | 09:57 AM
  #24
neo27ny's Avatar
Yep I think so...I may start the tear down but wait until warmer weather to finish cause I would like to strip it down to the frame and sandblast it and repaint it.
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
