2004 Sportsman 700 issues
Old Feb 28, 2013 | 08:28 PM
96z28fella's Avatar
Default 2004 Sportsman 700 issues
Well, new to forum and I hope you guys can help me out. I have a 2004 sportsman 700, it fires up fine and runs great until it warms up then its like it goes into a limp mode, no power. It has good compression, the drive belt has great travel. new plugs, new gas. Now the radiator has been patched up by previous owner with jb weld. if the radiator isnt flowing coolant correctly could that be an issue for no power? thanks
Old Mar 1, 2013 | 06:49 AM
Do you have the fuel injection or the carb model?? If you have the carb model,pop the front panel and see if you have the Ducati ignition or Kokusan. If it's a fuel injection model, could be a fuel pump issue.
Old Mar 1, 2013 | 11:02 AM
96z28fella's Avatar
Its actually a carb model. Carb has also been rebuilt.
Old Mar 1, 2013 | 01:09 PM
Check to make sure if you have an ignition module that says Ducati. It does make a difference if it does. It would be a combo cdi/coil together. If you have a Kokusan ignition,you will have a separate cdi and coil.
Old Mar 1, 2013 | 04:02 PM
96z28fella's Avatar
It does say ducati on it.
Old Mar 1, 2013 | 04:23 PM
That's probably why it's going into a limp mode. Look at all the posts on this forum and others,plus you can just Google up Sportsman 700 ignition problems. The Ducati system has been replaced with a Kokusan complete ignition kit #2202602. Comes with a new flywheel,stator,cdi,coil,reg/rectifier,jumper wires and instructions. Kit is about $450. Don't buy any new or used Ducati parts on Ebay or even from a dealer! Several places you can check on the best prices such as Cycle Parts Warehouse,Cheap Cycle Parts,Bike Bandit,etc.This was NOT a warranty item,but should have been! http://www.google.com/url?sa=t&rct=j...43148975,d.b2I
OPT
Old Mar 2, 2013 | 09:07 AM
96z28fella's Avatar
alright great thank you so much for your help. I appreciate it. Ill let you know how I make out.
Old Jun 8, 2013 | 08:55 AM
GripNRip's Avatar
Default so how did it work
how did everything work out for you.
Old Jun 10, 2013 | 08:30 AM
96z28fella's Avatar
Actually havent been able to order the parts an work on it. Wife an i just had a baby. Been busy! Lol
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Shifts
Jul 3, 2015 07:59 AM
