trail boss 250
trail boss 250
Trail boss 250 belt width is 1.188 inches I think. Mine is 1.07 something is that going to make a big difference on top speed? I ask cause I took it for a test drive yesterday and it didn't go very fast, maybe 20 mph. I have one on order just seeing if that's a main problem or I have a bigger issues I need to address. Thanks for any info.
KCCO
KCCO
You may have bigger issues such as worn ramp buttons in the rear clutch.http://www.cyclepartswarehouse.com/f...1999&fveh=5467
This is the tough part! You have to use a small drill bit through the broken screw then use a small ease out to try to remove remove it to save the threads in the clutch sheath.I never was too good at it! I've even tapped out the holes a bit larger and used larger torque screws(the recess slot in the ramp button has to be enlarged also) some would hold up,some I just had to replace the clutch if it didn't as you can't buy each clutch sheath separately. Plus I wouldn't trust one from Ebay.
Didn't think you would be able to! I never had too much luck on these small screws myself. Hope the one from Ebay is okay!
