2002 Scrambler 500 4x4 carb air screw tap size
Does anyone know what size tap the air adjustment hole threads are so that I can re-thread it? It`s the one on the bottom of the carb by the bowl. It`s # 32 on the parts diagram.
Thanks
Thanks
As long as you didn't break the fine tip on the adjuster in the carb body it can be replaced. The threads will be metric(don't know the size) but probably around a 4mm fine threads. Best to have a metric pitch gauge(in any metric tap set) to get the right thread pitch.
